-   -   what spark plugs with blower (https://www.offshoreonly.com/forums/general-q/71354-what-spark-plugs-blower.html)
timucin 02-09-2004 04:44 PM
do i have to use smthng special?
or go with the previous part #'s?
thnx
timucin 02-09-2004 04:55 PM
lower # = cooler right?
Reed Jensen 02-09-2004 05:18 PM
Numbers being higher or lower depends on the plug manufacturer... Ac plugs and Champion... The higher the number... the hotter the plug.... NGK... just the opposite. Smaller number is hotter plug.
Biggus 02-09-2004 06:04 PM
I'm running NGK 5673-8 they are two heat ranges colder than the AC MR43T
Cignificant 02-09-2004 07:48 PM
It also depends on your boost - I run 4-5# and use the MR43T and never have a problem.
Biggus 02-09-2004 08:14 PM
I'm running 8 lbs boost
WetKitty42 02-09-2004 10:22 PM
NGK
always worked best for me
merlin540 02-09-2004 11:31 PM
15psi boost @7500rpm i use ngk:D
Griff 02-09-2004 11:55 PM
NGK UR5's. They are the same heat range as an AC41.
They might be the same as the ones Biggus posted the # for. UR5 is the # on the plug. There is a different stock # on the box.
RMPRam 02-10-2004 07:03 AM
I run anywhere from 10 to 15 lbs of boost, depending which top pulley I run, and use an NGK #6061.
That series of plugs has a huge ground electrode and are designed to be used w/blowers.
The only problem that you may encounter with this particular series is that they use a 13/16th plug wrench, not the small 5/8th's that most use. I turned the outer dia. of the large wrench down and it just fits in the head to put the plug in.
In my opinion NGK is the only plug to use in this application.
