disc brakes ?
I need some help with a purchase two set's of disc brakes for a tandom trailer , there's two different brands Kodiak and Tie Down . Tie are stainless and the kodiak brand is e-coated any pro's and con's Thanks Jeff
Go with the stainless if you are going to put it in salt water... Flash plating will be gone in a couple of dunks in salt.
I put the stainless ones on my trailer three years ago and they are great. My buddy just did the other style this winter....we'll see aboout them:rolleyes:
Disk
1 Attachment(s)
We use both the tie-down and Kodiak brakes on the trailers. Request are about 50/50 between the two. Prices is same for either.
Kodiak has a CAD coat, ECoat and Stainless version, Tie down are stainless with a Ecoat caliper. Tie down has the advantage of a stainless rotor and an aluminum ECoat caliper at an economical price. Pads are unique to Tie-Down. Kodiak Stainless includes a stainless caliper and are double in price. The Kodiak CAd coat is comprable to tie down in price. These are vented disk brakes with a removable rotor you can turn and large Marine version of the GM calipers. Brakes are GM pads. Bake pad surface area is probably double on the Kodiak. Both offer reliable and smooth operation. Again, both are great brakes so weight out which features are best for you. Be sure to use a coupler set up for disk brakes. You can modify your coupler if you are converting. This is the tie down |
Tie down caliper
1 Attachment(s)
Ecoat caliper
Kodiak
1 Attachment(s)
Large rotor and vented CAD Coat - this is the 5 lug 14" wheel brake
1 Attachment(s)
Another view of the Kodiak
I installed two sets on a trailor of the Tie Downs and they work great.
| All times are GMT -5. The time now is 08:40 AM. |
