500efi Valve Springs, Help??
I know this has been covered before, but I feel I need to replace my Valve springs, I have a 2001 500efi w/ 280 hours.
1. Exactly what needs to be replaced, Valve springs, Lifters,??? and what mfg would you replace with, I have been told Isky?? 2. Anyone personally suggest a mech in VA ?? to do the work? All input is really appreciated when it comes to engines:crazy: WILL;) |
Will,
if your interested I have set of NEW ISKY 8005-A springs for that setup. They are currently on my new heads but I'm upgrading them for a larger cam. $75 delivered. Dave [email protected] |
Valve train updates.
27Fountain,
If you need to find a good shop to do your valve train update, give BK a call at Offshore Performance in MD. We have plenty of certified tech's and can get you done in a timley manner so you wont miss any boating season. Pwrbt33 Offshore Performance 1-877-GOFAST1 410-827-0200 |
27 Fountain, I'm in the same position with the same year and engine and hours. I'm replacing just the springs with stock Merc. They have worked for me this many hours, so.....
Time for a new set of lifters if ya ask me. Ever seen a block explode when a lifter roller pin comes loose and hits the bottom of the lifter bore? Not a pretty site at all. And while you're at it, a new set of crane 1.8:1 rocker arms will pick up a bit of power for you.
Quote:
Quote:
But it will put your mind at ease about the the shape of your piston rings. Asuming the test is good. |
Nordic and Pwrbt,
Thanks, I am still looking at all of what i am in for. I will let you all know something when I figure it out;) |
| All times are GMT -5. The time now is 08:22 PM. |
