-   -   GPS Speedo's (https://www.offshoreonly.com/forums/general-q/72035-gps-speedos.html)
Active Mike 02-17-2004 10:19 PM
GPS Speedo's
I was wondering does the receivers for the GPS speedo's have to be exposed for them to work or can they be tucked away???
Dave F 02-18-2004 06:19 AM
My "Puck" as they call it, is under my fiberglass/wood fairing. So, no. They don't have to be out in the open.
DAVE
cobra marty 02-18-2004 06:25 AM
I allways heard that the antenna/puck had to be able to 'see' the sky/satellite. But if it works under the deck that's great.
audacity 02-18-2004 07:00 AM
we have 2 antennas mounted under our kevlar deck and 2 under/sides of our canopies.
Scott 02-18-2004 08:48 AM
1 Attachment(s)
Wow a thread that shows proved facts:eureka:
Mine has been under the dash for two seasons with zero problems.
If you have not mounted your tattletale switch yet you may want to consider a switch that matches or even an empty acc. switch that you can change over to a momentary switch. Just a thought (can you tell I don't care for the switch it comes with).:D
Reckless32 02-18-2004 12:18 PM
Great. This helps squelch an old myth. Now on to more practical info. Who has the best deals on analog complete GPS units both standard and Monster series?
rbtnt 02-18-2004 07:56 PM
I'm with Scott, use switches that match. I had a new switch panel made with engraving for the GPS switch.
Turbojack 02-18-2004 08:06 PM
I like the digital better. You can see exact speed & can tell when you over or undertrim very quickly.
Cord 02-18-2004 09:14 PM
Try Fred. He's just getting into this business.
Active Mike 02-18-2004 09:22 PM
scott,
that is a good idea. what do you have to do to do this?
