Corsa Muffler Tips???
1 Attachment(s)
How much will these quiet my exhaust down over straight thru tips???
It gets annoying in the no-wake zones at idle, its just a basically stock 350. |
1 Attachment(s)
going here
it'll quiet them down a lot.....i had the quick and quiets on mine....took them off for straight throughs, night and day difference.
Originally posted by 97BossHammer it'll quiet them down a lot.....i had the quick and quiets on mine....took them off for straight throughs, night and day difference. |
Hammer, why did you take the Quick and Quiet off? Too quiet for you? I have the Q&Q system I'm about to install in my Formula.
I run them on a 502.. definitely take the snarl out of them but still sound healthy enough. Still have switchable option through down tubes so if there is any backpressure I believe this helps bleed it off. No appreciable performance loss as far as I can determine.
Originally posted by madbouyz I run them on a 502.. definitely take the snarl out of them but still sound healthy enough. Still have switchable option through down tubes so if there is any backpressure I believe this helps bleed it off. No appreciable performance loss as far as I can determine. Now I need some new toyz!!!!!!!!!!!! |
| All times are GMT -5. The time now is 08:26 AM. |
