Cant view the pic but are these the corkscrew type baffles? If so, I had them in my boat and picked up several MPH by cutting them out. Stock 330hp 454.
On CP perfpramance's website under the muffler section the have a test on a 25' Daytona with a 502 mag. The boat did drop 12 db, but it also dropped 200 rpm.
The Hardin Marine one at the top looks the same as the double X.
http://cpperformance.com/products/Exhaust/024.htm |
Originally posted by Pantera572 Tried a set on a 305 chevy in a small Donzi. Worked well. Took off some of the harsh sound. Don't think I would try them on much higher HP applications. Just bought a set of GGB muffler tips for a Merc 525. Designed for high HP motors. Will be posting photos and results in about a month. Greg |
slip-ins
I installed a pair that look the same as in the pic, If I remember right I got them from Rex Marine. They seem to work well for me. I had to do something,I think it sounds good. I'm still not sure how it would do on a db meter and I don't think it would get the approval of most tree hugger types. I will say,I do boat where there a little sensitive and nobody's bothered me so far. As for performance loss I only ran it on the trailer without them. But I feel the boat performs as it should with a stock 7.4.
I tried them on my 502 mag. and lost 200 rpm, and also the tailpipes got so hot you could even touch them normaly they are only warm to the touch. I drilled a bunch of holes in the center plate and that helped a bit, but i only use them when there is a chance of a problem.
They do cut the noise down quite a bit. |
I inquired about the same mufflers at CPPerformance. They said 100-150 rpm loss. I said No Thanks.
Splashandburn,
GGB advertises in the classifieds under exhaust. They also have a website. GGB.CA. I think. Wait a while for it to load. Greg |
Originally posted by Pantera572 Just bought a set of GGB muffler tips for a Merc 525. Designed for high HP motors. Will be posting photos and results in about a month. Greg |
Bam, Bought the extreme variable.
Looks like it will be done in two weeks. I'll post pictures and my thoughts asap. |
| All times are GMT -5. The time now is 07:46 AM. |
