-   -   Which pan gasket for GEN V 502? (https://www.offshoreonly.com/forums/general-q/72987-pan-gasket-gen-v-502-a.html)
HPJunkie 03-01-2004 05:13 PM
I need to replace the pan gasket on my gen 5 502, its leaking at the bottom of the timimg cover where it meets the pan. Is there a special gasket I should use and are there any little tricks to increase the success of the replacement? Thanks Greg:confused:
US1 Fountain 03-01-2004 06:07 PM
I used the Felpro. If I recall correctly, you are instructed by Felpro to put a bead of RTV in both the timing cover and rear main cap grooves before installing the gasket and in the corners as well. I had no leaks doing it that way.
38KV 03-01-2004 06:40 PM
I use RTV all over the surfaces when I'm installing BBC oil pans.
And I'm not torque the bolts all the way before the RTV is dry.
Never a leak so far.
HPJunkie 03-02-2004 06:51 AM
38kv did you say that you dont torque the bolts all the way until the rtv is hardened? Greg
38KV 03-02-2004 11:40 AM
Yes,I torque them about 50-75% of the recomended 80 lbs.inch for the 1/4" and 165 lbs.inch for the 5/16" when I install the oilpan,and torque them all the way the day after.
