-   -   Alternator current output (https://www.offshoreonly.com/forums/general-q/73280-alternator-current-output.html)
p4-33 03-05-2004 09:57 AM
I've got stock HP500 (carb) alternators, and I'm doing a significant audio upgrade. Anyone know what the current output is on my alternators?
Thanks,
Brian
deboatmon 03-05-2004 10:15 AM
I believe most Delco's are 60 amp. You probably need more battery power to supply adequate power for a serious amplifier. The alternator might not be able to deliver the peak current required of a high powered amp or amps.
Good luck.
Smitty 03-05-2004 12:13 PM
Add some extra batteries and a few capacitors and yuo'll be fine.
