Will XR Drives fit on a ?
Will it fit on a standard bravo 1 Transom Assembly ?
Also is the Drive any longer or shorter than the standard bravo 1 ? This is for a single engine 29' Power Quest with a 540 ci in it. I don't think the power is as hard on the current Bravo as the weight is. Thanks for any help. Cougarman |
Yes it will, but you must change the gimble bearing. (The new one has a red dot on it.) Other than that the drive will mount up fine and it is the same size.
Xr upgradeclick here
Be sure to put a good drive shower on it. Those straight cut gears run hot.
You also need to put a spacer in the trim cylinders to prevent U -joint from binding in the event you ran the engine in trailer position. The trim cylinder end cap is removed and a small plastic spacer is inserted to limit the trim up. Merc has a PN for the whole kit, gimble bearing, seal behind gimble bearing and limit for the cylinder. There may have been a piece for the bellows, can't remember but it had to do with clearance for the larger U-Joints.
| All times are GMT -5. The time now is 10:45 AM. |
