aluminum heads
What are the pros and cons with aluminum heads in marine applications?.. I hear Edelbroc makes a great set of heads for the HP 500. Is corossion a problem? Has anyone had any experience with aluminum heads? What do they cost?
I would be interested in an answer as well. I used Brodix aluminum heads on the motor in my last cat, but it was a fresh water only boat.
I have heard some say that they would be ok in salt, and some say they would not.:confused: |
need to be hardcoat anodized, salt will eat the heads quicker than the fresh water , but even fresh water they will get eattin up just takes longer. best route is closed cooling, imho...
Salt?
So.. How long would a set of aluminum heads in saltwater last?... If they were flushed well after each use in saltwater?
I just built a 540 with AFR heads.I chose to go with aftermarket closed system and not worry about it.I've heard 3-5 yrs with open systems.BOB
| All times are GMT -5. The time now is 04:00 PM. |
