-   -   Bottom (https://www.offshoreonly.com/forums/general-q/73701-bottom.html)
dowhat 03-10-2004 07:54 AM
Bottom
I have noticed that the bottom of my boat is starting to yellow. I keep it on a lift out of the saltwater. What is the best product to use to clean the bottom.
What about rubbing compound?
Also what about an extremely fine grit sandpaper for more speed?
offthefront 03-10-2004 01:29 PM
I think you can use like "Tidy Bowl " or any of the tollet cleaners .....they have a mild acid in them that will remove the yellow .....prob need to get that verified ..but I believe I am right ....
Griff 03-10-2004 02:50 PM
Muratic acid. Use a pump garden sprayer to spray it on. Probably shouldn't use it while on the lift. The fishy's won't like it.
Doller Offshore 03-10-2004 03:24 PM
on-off,spray it on,hose it off.and it doesn't hurt
the wax
Gary Anderson 03-10-2004 03:25 PM
Probably shouldn't use it if the wind's blowing either. Your skin wont like it.
Gary
Downtown42 03-10-2004 04:51 PM
Starbrite Hull cleaner is maybe more mild. I use it sparingly works well. Keep everything wet with your hose. You have a 1999 I don't think I would use sandpaper unless all else fails.
Downtown42 03-10-2004 04:53 PM
Wouldn't recomend rubb comp either
