-   -   can i determine cam with out teardown? (https://www.offshoreonly.com/forums/general-q/73761-can-i-determine-cam-out-teardown.html)
CONDOR24 03-10-2004 06:52 PM
hey guys, i bought a marine crate 502/502,its suppose to have the crane 169611 roller cam and all the goodies that go along with it to make an hp500. i'm worried i might of received a 415/502. is there a way to measure the cam without tearing down the motor?will pulling a valve cover tell me anything?
magnum 03-10-2004 08:00 PM
if you have a dial indicater you can check cam lift and compare specs.Otherwise you'll have to pull the timing chain cover and cam sprocket and hope the cam is marked.I personally don't know of any external differences but do a little more research,maybe they use a different intake or head casting.Good luck and hope you got what you paid for.
mcollinstn 03-10-2004 08:49 PM
All Cranes are marked on the sprocket end with the grind number.
Dial indicator on a magnetic base plus a big breaker bar with a socket. Can measure lift with the valve covers off.
A 502/502 has aluminum heads
Ric232 03-10-2004 09:10 PM
The 502/502 also has a GMPP cam, unless you bought it from someone who swapped it.
mcollinstn 03-11-2004 08:37 AM
Yeah, but he's saying it has "add ons" to make it a HP500...
Add ons to a 502/502 would be:
install a marine dart intake and Holley marine 800 with a USCG approved electric fuel pump
Install a Merc TB4 ignition
Swap out the cam
Swap out the lifters
Install Crane Gold rockers
Brass freeze plugs
Marine head gaskets
paint it blue
*also the heads are different, but in freshwater the edelbrock aluminum head is a good un
Gary Anderson 03-11-2004 09:09 AM
If you've got degree markings all the way around the balancer, or a degree wheel, and a dial indicator on the valve you can at least read duration, lift, and lobe centers.
Gary
