-   -   Pressure gauge off the raw water pump? (https://www.offshoreonly.com/forums/general-q/73909-pressure-gauge-off-raw-water-pump.html)
jbrauer 03-12-2004 06:03 AM
I know we've all visited this topic many times, but I don't remember ever seeing this question -
I'm reinstalling my motors (HP500 carbs) and noticed plugs directly on the the inlet and outlet of the raw water pump. Would the plug on the outlet side be a good place to get water pressure for my gauges? Do you think there would be too much turbulence from the pump?
Thanks, Jeff
BadDog 03-12-2004 07:07 AM
Taking a pressure reading there may be a reliable indication of pressure but not the pressure reading you want. Measuring at the pump would possibly show higher than block pressure readings as the gauge will see restrictions in the plumbing system. Just measure it at the block drain plug as this is the pressure your intake manifold and head gaskets see.
mcollinstn 03-12-2004 07:53 AM
block pressure is your concern.
If you just want a zillion gauges then tap them both places.
I like gauges...
Notched_Baja 03-12-2004 05:39 PM
I was using the drain fitting on the side of the block. I changed it to a fitting on the intake manifold next to the water temp probe. It is much easier to get to if it gets plugged up with something.
mopower 03-12-2004 07:37 PM
I have mine on the t-stat housing right next to where the line comes in from the oil cooler.
WILDTHING TAZ 03-13-2004 01:45 AM
I HAVE MINE AT WATER CROSS OVER. INTAKE & CROSS OVER ARE THE BEST PLACE TO PUT THEM. NO CHANCE OF DIRT & SAND PLUGING THEM UP.I HAD A STAINLESS FEMALE FITTING WELDED INTO CROSS OVER IS WHERE I HOOK INTO.
