| 32storm |
03-13-2004 08:37 PM |
It sounds like you have the Bennet trim tab indicator system. if it's not working, normally (1)of two things: a) the indicator sending unit( part that is contained in upper part of hydraulic cylinder is gone, or (2)the CPU unit is shot. Unless your boat is not used at high speed, and/or not used in rough water, this system will not hold up. Bennett is great at sending parts. They have really excellent service. But, it won't fix a design not up to offshore standards.
I had them on a Formula. Biggest pieces of garbage. Tabs worked fine. But on the indicators, I replaced multiple CPU's and sending units. Bottom line, that portion of the system was junk for speeds and usaege my boat was seeing.
