-   -   K&N filters and the Coast Guard.. (https://www.offshoreonly.com/forums/general-q/74232-k-n-filters-coast-guard.html)
dyno 03-16-2004 10:06 AM
are they CG approved? can you get in trouble if you run them without approval?? I know most of the blower guys run them.....but the only one thats cg approved is the small one...
JohnJan 03-16-2004 10:36 AM
Coast Guard approved air filters will say so on them.
dyno 03-16-2004 11:17 AM
So the nice big high flow K&N's are illegal???
Crazyhorse 03-16-2004 11:22 AM
Jeg's and Summit both offer a K&N that is C.G.-approved.
formula31 03-16-2004 11:23 AM
Mine said CC approved on the box but no where on the unit itself. I figured that would be a problem if inspected.
dyno 03-16-2004 11:45 AM
Yeah but its a little bitty one!
Crazyhorse 03-16-2004 02:01 PM
Yeah, I know. I'm looking around to find a C.G.-approved arrestor setup that will flow enough for my motors. I lose 50 horsepower just by putting on the flame arrestor that I have now.
dyno 03-16-2004 02:59 PM
I like the larger oval ones!!!
mopower 03-16-2004 03:06 PM
1 Attachment(s)
Took mine off my 540s... they didn't flow enough. And it was stamped USCG Approved on the metal top. Also on the rubber on the little filter. The larger ones aren't.
I switched to Eddie Marine 10X5 stainless arrestors:)
wwwTOPDJcom 03-16-2004 04:06 PM
1 Attachment(s)
hell this one says mercury on it, what else can they say
JPD Motorsports 03-16-2004 10:14 PM
Asked the folks at BDS about the k&n's and they told me that all the filters are now cg approved, I think got the approval in Jan or Feb this year? From what I can recall on the dates.
mcollinstn 03-17-2004 08:31 AM
I've stacked a bunch of standard Merc F/A's on top of each other before.
The little "normal" 330 sized arrestor. Those are give-aways from the local boat hop up shop. They have no use for them.
Cut the top out with a nibbler, leaving enough rim to poprivet it to the bottom of the one you'll put on top of it. Cut the bottom out of the next one the same way and put a bead of 4200 black on the rim and sandwich em together and poprivet them. The 4200 is just to keep them from rattling - silicone will melt after a while from the gasoline - use 4200.
I made two QUAD stacks of these for a bud running dual carbs. He liked the look. Still running them.
They seem to work very well.
And they re "made from" USCG approved pieces.
Keith 03-20-2004 12:58 AM
Eddie Marine and some of the K&N's are specifically USCG Approved, containing a designation stamped in the housing, or on the filter/arrestor itself. If it's not there, USCG will write the citation and basically end your day of boating. That's typically one of the first things they check every time I've been stopped.
