-   -   cam specs. (https://www.offshoreonly.com/forums/general-q/7435-cam-specs.html)
traviss 01-30-2002 07:37 PM
cam specs.
Does anyone know the cam specs for the mercruiser chevy 377 scorpian motor?
Was it a Roller cam?
Did merc every put roller cams in late 80's 350 chevy 270 hp mag motors?
Travis
Cord 01-30-2002 08:49 PM
GM was stabbing roller cams into small block after '87.
Iggy 01-31-2002 02:43 PM
Somewhere in mid '88 Merc switched to roller cams in th sbc. All new ones have the roller type.
I have an '88 350MAG, 270 hp motor but it has a flat tappet cam. Merc made the switch after mine was built.
BajaRunner 01-31-2002 04:28 PM
so my 87 350 mags are the flat tappet?
Iggy 01-31-2002 06:19 PM
Probably so.
If you take your engine serial number and go to the merc web site then go to parts express, pulg in the S/N and you'll see. On mine they listed two ranges of serial numbers, one with roller cam and one without.
[ 01-31-2002: Message edited by: Iggy ]
