-   -   Trim cylinder interchange. (https://www.offshoreonly.com/forums/general-q/74512-trim-cylinder-interchange.html)
mrstage1 03-18-2004 10:10 PM
New Scarab owner in Kansas here. I finally found a '77 Scarab 300 to restore(had to be a '77 for sentimental reasons)and I'm having some trouble locating trim cylinders for the TRS drives. Anyone on here have a lead on where to purchase all 4 cylinders and the trim pumps? I'm not too proud to go with good used units either. Will Bravo or other cylinders work since they are seemingly easier for me to find around here. As you can guess there aren't too many offshore style boats in my neck of the woods so my parts contacts are slim to none. Any help would be greatly appreciated.
marinetrans 03-19-2004 07:32 AM
If I were you I'd change over to a high volume trim system now.Newer TRS had this trim system.The stuff you have now is high pressure, its slow reacting. Since you need trim pumps and cylinders its the way to go. Any OSO Merc advertiser here can help you.
Doller Offshore 03-19-2004 08:11 AM
maybe we can help,we have new and rebuilt parts
for your trs's.we probably could get you set up with
any other projects you're working on.give us a call
800-376-1616.
art
mrstage1 03-19-2004 02:59 PM
Thanks for the replies. I'll be a callin' for sure.
