Saltwater Flush .... >
Old 03-28-2004 | 07:53 PM
  #31
Ric232
Originally posted by alter ego
What do you think of putting a closed cooling system on? It is kind of expensive at first but then you don't have all these flushing problems after every use. The engine itself will stay salt free, all you would have to worry about is risers.
You still have to flush the heat exchanger.
Old 03-29-2004 | 09:40 AM
  #32
mr_velocity's Avatar
Originally posted by Panther
I'd like to know what is in salt away also. I thought it may be some type of acid, which is really bad if you have Aluminum heads, intakes and manifolds.
It's not acid, it's soap of some sort. Probably just overpriced dish soap but it does work. Usually on Saturday afternoon if I know I'm going to use the boat on Sunday I just spay the whole boat down with the stuff and rinse it off. Also spray the drives down with it.
Not sure if nontoxic antifreeze will be cheaper in the long run. I use about 3 oz to flush both motors and spray the drives down.
mr_velocity is offline
Old 03-29-2004 | 11:51 AM
  #33
Ric232
Antifreeze is about $8 per gallon. Salt Away is $33. Still, I don't know if antifreeze (non-toxic) will do the trick.
Old 03-29-2004 | 12:38 PM
  #34
Steamin Rice's Avatar
Salt - Away seems expensive, but I don't mind paying $30 once or twice a season to use it. It's not that much money compared to the other costs of the boat.
Steamin Rice is offline
Old 03-29-2004 | 01:02 PM
  #35
But what will you do with the antifreeze? With the salt away I use about 3 ounces in their dispenser. Would you do with same with anti freeze? Does anti freeze also neutralize the salt? If you believe what salt away claims to do.
Old 03-29-2004 | 06:47 PM
  #36
Ric232
You use the same dispenser. If someone doesn't already have one, they can get one at the local garden center. I don't know if the anti-freeze neutralizes the salt. That's the whole purpose of this thread. We're speculating and someone has offered to test the theories.
The other thing I'm unsure of is whether it's really safe to let non-toxic antifreeze drain out of the motor w/o collecting it. Yes, it's non-toxic, but it's probably not biodegradable or safe enough to let it go down the storm drain. I honestly don't know. And I'm a big proponent of disposing of things properly and using the most environmentally-friendly alternative available, assuming it is effective.
FeverMike
03-15-2008 03:05 PM
crsnang
11-23-2005 08:08 PM
Frequency
5
04-02-2003 07:11 PM
outlawinil
4
12-22-2002 05:55 PM
bucky
12-20-2002 06:55 PM
