How to boost reference a Holley
I'm trying to learn how to boost reference a holley. I have a Holley 1000 HP carb to reference and on another boat I have two 750 Holleys vac secondary's. Can you please send me some info. I could used a drawing of some sort. Thank you
Boost referencing means that the power valve takes it's signal from the manifold below the blower. You have to plug the existing power valve port and drill a new passage to the power valve. This is connected to the manifold via a hose.
Unless you want to take the chance of damaging your carb, it's best left to an experienced carb/blower shop. Do a seach in the Tech section on boost referencing, these some info from much more experienced people than myself. Gary |
| All times are GMT -5. The time now is 09:17 PM. |
