-   -   Mercruiser BB Thermostat Housing conversion? (https://www.offshoreonly.com/forums/general-q/75028-mercruiser-bb-thermostat-housing-conversion.html)
Danny_Ocean 03-24-2004 09:26 PM
Motor: Mercruiser 330/454, raw-water cooled (standard cooling), TRS.
I'm converting from log-style manifolds to center rise. Now that I'll only be using two hoses per side (manifold/riser), my existing thermostat housing has four extra water outlets. Can I block-off the unused outlets or must I upgrade to the new-style thermostat housing?
Thanks in advance,
D. Ocean
Pompano Beach, FLA
marinetrans 03-25-2004 06:47 AM
Block off the riser water ports and use bottom ports in manifolds for the water to exit. You use the boat in warm water, so I'd use riser gasket# 27-863726 (if your using Merc manifolds). Use 140 thermostat and drill 2 3/16 holes in thermostat flange.
Danny_Ocean 03-25-2004 08:38 AM
OK. That set-up uses only one hose per side, so now I'll have six unused outlets on the thermostat housing to deal with. Do I just cap them off?
Thanks,
D. Ocean
Pompano Beach, FLA
rchevelle71 03-25-2004 09:40 AM
Here ya go,
http://cgi.msn.ebay.com/ebaymotors/w...tem=2469191527
Not sure if the V-6 one is the same as V-8, but you get the idea!!!
Danny_Ocean 03-25-2004 07:24 PM
No, not the same. Yes, I can purchase the correct housing for $150, but then I have to drill/tap to move the intake to the correct side. Much easier to cap-off existing outlets, if that is allowable.
Anyone?
D. Ocean
Pompano Beach, FLA
