-   -   Custom Lab Finished 5 Blade Props (https://www.offshoreonly.com/forums/general-q/75070-custom-lab-finished-5-blade-props.html)
HOUSTONPROP 03-25-2004 02:43 PM
1 Attachment(s)
Power-Tech did the casting and we are doing the lab finishing work ,with or without a polished finish.
Use your current hub inserts (same as B-1)drop in.
props are made of the same material as Merc 17-4 stainless ,no weld on blades and heat treated against blade failure.
order yours today .:) this can be built in any pitch you want.
HOUSTONPROP 03-25-2004 02:47 PM
other side
1 Attachment(s)
drop in hub cavity.
robyw1 03-25-2004 02:53 PM
Darin, would this benefit me better than what I have?
Roby
HOUSTONPROP 03-26-2004 11:41 PM
ROBY1
1 Attachment(s)
The current prop you now have is probably the best prop for your boat
,You can order one for a spare:D
THE ACCLERATOR designed by,Houston PROP
