-   -   trim up, no trim down (https://www.offshoreonly.com/forums/general-q/75092-trim-up-no-trim-down.html)
KH0302 03-25-2004 05:49 PM
Just pulled the boat out to change all fluids to full syn. Trims up, no downski. Buddy says replace down solenoid(green wire) with a Ford starter solenoid...thoughts?
Kurt
Revd Up 03-25-2004 07:35 PM
Chech the trim switch on the throttle. I've had them work one way and not the other. Otherwise check into the trim sender switch on the side of the outdrive.
Steve
Payton 03-25-2004 08:04 PM
Check the fuse on top of the solenoid before you change the solenoid. Then jump the solenoid to make sure it's the problem.
I don't know what dif, besides price, there is betwqeen marine and automotive.
Hot Boat 03-25-2004 10:40 PM
What Payton said
jpclear 03-26-2004 08:51 AM
If the pump motor itself is not running, (I assume this is the case if you are talking about solenoids) have someone hold the "down" button while you tap the solenoid, but not hard enough to break the plastic. Sometimes they hang-up after setting all winter and once you jar 'em awake they keep right on working. --- Jer
Gary Anderson 03-26-2004 10:57 AM
Got a voltmeter or test light?
Hit down on the trim switch, check to see that the solenoid is getting power (usually the small green wire).
If no power, check your trim switch or connections.
If yes, see if power is going through the solenoid. See if the large red wire is hot. When the down button is pushed, the large green wire should be hot. If not, check the connections or replace the solenoid.
If voltage goes through the solenoid to the motor and it doesnt run, replace the motor.
Gary
aero-offshore 03-26-2004 03:19 PM
What jpclear says, I have to every season
KH0302 03-26-2004 05:15 PM
Well it seems that if the pump was gone it wouldnt go up either...???
Fluids low as heck too, same buddy said Dextron. True?
Gary Anderson 03-26-2004 05:29 PM
KH0302
The pump has 2 sets of windings (3 terminals). They dont just change the polarity. One set of windings can burn out while the other still works. At least that's the way I understand it (where's mcollinstn when you need him?)
Gary:D
KH0302 03-26-2004 06:40 PM
I jumped between green and red and down works, so I'm gonna replace both solenoids tomorry.
Thanks for the help again, guys. (i wish we had a freaking thumbup icon)
