Hatch Actuators
One of mine seams to be malfunctioning. Has any had any sucess with rebuilding the electic motors? It is a Warner Electric from Eddie Marine.
i pulled mine apart last season when it died. The brushes and contacts were filthy . I cleaned it up with some carb cleaner and re assembled it. It worked like new when I was done. Good luck
Paul |
You should be able to find a replacement moter here if you can't rebild it.
http://www.grainger.com/Grainger/wwg/start.shtml |
mine was real slow going up . tore it apart and it was dirty in the gear section , the motor was all rite.cleaned and greased and it working better:D
If you're going to take it apart to clean it, use electrical contact cleaner, or brake cleaner. It's a lot less nasty on the motor parts than carb cleaner.
| All times are GMT -5. The time now is 12:58 AM. |
