-   -   Internal Flappers replacement?? (https://www.offshoreonly.com/forums/general-q/75149-internal-flappers-replacement.html)
FunHome 03-26-2004 08:57 AM
While I am replacing the my exhaust, I had everything off except for the Tips and noticed that the stock internal exhaust flaps were missing. I have External Flappers as well and I'm debating whether I should replace the internal ones.
If I were to replace them, how do the new ones go on?? Does a new rubber flapper just connect to the Rod that is already in place?? The Rod is riveted in place, do I have to drill out the rivets and replace the rod and flapper??
I did a search on this topic and found info. on everything except "how to" replace the flappers.....
KCHOTBOAT 03-26-2004 09:17 AM
Brad it is real easy. Punch out the pin. The new flaps should come with new brass ends.
FunHome 03-26-2004 09:56 AM
Rich what do you mean?? Bunch out the Rod?? Do the rivet stay in place??
KCHOTBOAT 03-26-2004 10:05 AM
Are the tips off the boat? If so I can show you how to take them out. Stop by sometime and we can redo them.
Give me a call later.
