-   -   Merc 575sc's & Mobile 1 15W50 (https://www.offshoreonly.com/forums/general-q/75190-merc-575scs-mobile-1-15w50.html)
InXS 03-26-2004 05:31 PM
Have '02 Mercruiser 575's, 42' Cig; 80 hours on engines. Boat runs in fresh water. Was thinking of going to Mobile 1, 15W50 oil, instead of Mercruiser 25W40 stock oil. I was looking for any input/advise if this was the correct weight and viscosity oil to use or not. Any expertise on this?
Thanks, InXS
zahndok 03-26-2004 08:54 PM
I don't know either but I just bought the same oil for my 02 575 with 100 hrs. Have been running kendall 20-50 dino juice. Trying to decide also whether to put the Mobil 1 in over the Kendall.
mcollinstn 03-26-2004 10:41 PM
15-50 Mobil 1 will be fine.
If you're not running thermostats, 0-40 Mobil 1 is a good choice.
Active Mike 03-26-2004 10:52 PM
If you want a real good oil to run Royal Purple Racing 51.
It is an oil design for extended periods under extreme pressure and heat.
A little $$ but worth it if you are looking for a real good oil.
It's viscosity is typical of a 20W/50.
Bob280Silencer 03-26-2004 11:02 PM
RoyalPurple Racing 51 ,yep,thats the one.I ran it in my 2001 HP500 for 280 hrs & I'm going to run it in my new 540.BOB
