-   -   How do you install freeze plugs? (https://www.offshoreonly.com/forums/general-q/75246-how-do-you-install-freeze-plugs.html)
Formula78 03-27-2004 04:48 PM
The Machine shop forgot to install the big freeze plug in the back that the cam rides against. (I know I know, trust me I'm never going back) Anyways, I have a set of freeze plugs and I'm going to try and install that one. How do I do that? Just hammer it in? I have no idea.
DanB 03-27-2004 05:17 PM
just tap it lightly to get it started square, then take a round object like a socket that just fits in and bottom it out. I always put a bead of silicone around it for insurance. Dont forget to use brass...not steel plugs.
Formula78 03-27-2004 05:26 PM
Thanks! It's the big one behind the cam so it will be steel. The rest are brass.
Vinny P 03-27-2004 06:44 PM
I would not recommend using silicone on freeze out plugs or that cam plug. I always like to use brown aviation glue.
Formula78 03-27-2004 06:47 PM
Where do I get Aviation glue? Will anything else work?
38KV 03-27-2004 07:59 PM
Loctite #5923
paradigm shift 03-27-2004 09:03 PM
Buy the way the cam does not ride against the plug so do not tap it in to deep. If it rubs you will have trouble. Hope that is the only plug your builder left out. :rolleyes:
Vinny P 03-28-2004 05:48 AM
Most auto parts stores carry it. Permatex makes it.
MACDAD260 03-28-2004 06:51 AM
Drive the plugs in until the outer edge is flush with the block, no more, no less.
Comanche3Six 03-28-2004 08:25 AM
This is crucial! Follow these instructions. The plug you are going to install is not a freeze out plug, so the depth of this steel plug has consequences. If you are not comfortable in doing the job, then have someone with experience help you.
Good luck
Ed
