-   -   TRS Tranny Question (https://www.offshoreonly.com/forums/general-q/75455-trs-tranny-question.html)
Poorsche 03-30-2004 09:29 AM
TRS Tranny Question
I had to pull the TRS drives on my Formula SR357. The boot had transmission fluid in it.
The mechanic is sayin neeed to pull engine and re-seal the tranny.
Is it possible that it got overfilled and that is overflo?
I got enough pain right now rebuilding the drives that got badly zapped by electrolysis from home-made barge the marina parked next me.
Thanks for help--
BTW--pics of boat in FORMULA forum and pics of Arnesons posted also
Poorsche
marinetrans 03-30-2004 09:44 AM
Yep, got to come out and be re-sealed. May need Merc# 57758a2 yoke if its pitted too (expensive). Seal rides on that yoke (need good seal surface).
Gary Anderson 03-30-2004 09:48 AM
Overflow would probably come out the vent or dipstick. That would end up in the bilge too. Replace the rear seal. Not sure if you could do it through the transom, but I'm sure that would be kind of a pain.
Gary
Zanie 03-30-2004 09:49 AM
Is it the merc trans or the BW trans?
Poorsche 03-30-2004 11:19 AM
Trs Tranny
It's the BorgWarner--1987 vintage
force 320 03-30-2004 09:55 PM
Yip, What marinetrans said, I just rebuilt my B/Ws. Engines must come out, the seal is in the tail stock housing area. might as well up grade tranny clutches. I warped my stock brass clutches with only 420 hp. I rebuilt both with graphite clutches for 150.00
Panther 04-01-2004 10:27 AM
force 320,
where did you order the Graphite clutches? I just replaced a trans and now I have a spare that I want to rebuild and or sell.
Panther
open87 04-01-2004 11:05 AM
aftermarket marine 504 888 2798 or 1 800 fix boat. ask for sean.
Awesome35 04-06-2004 02:24 PM
I also have 2 questions on Borg Warner trannys & TRS drives.Mine are the oriiginal units in my 1976 Cigarette Awesome. When doing alot of forward & reverse shifting Idling through a busy cove,the transmission fluid wants to all boil out of the vents.
The 2nd question is when I put the trannys in reverse they squeal. They have done it since I have had it & when the previous owner had it. I have not run the boat very much in the 1 1/2 yrs I have had it.
jaybird 04-06-2004 04:02 PM
How much work is it to rebuilt these with the new clutches? I have both my motors and trannys out, and while they are out should I put new clutches in? The tranny's work fine, but I am pushing about 550 hp, which seems to be close to the limit.
open87 04-06-2004 10:38 PM
best thing for the vents is to plug up the little vent and make your fill tube a vent with a 8 inch piece of tubing and put a clamp on k/n filter on top real easy to do.;)
Audiofn 04-07-2004 12:05 AM
Open you got any pictures?
Jon
open87 04-07-2004 06:48 AM
Jon
call drew at drew marine # 509 535 3393. this is his trick that he came up with and i don't want to take credit for someone else's idea.
laketahoe 04-15-2004 09:26 PM
Transmissions
.rebuilt a B/W 71 C's two years ago have three hundred hours on them. Behind twin 's 502. The B/W 71C are primarly used in backhoes and road graders and drag cars. Grafite clutches are good up-grades but, you can get cavalar coated clutches same stuff that bullet proff vest are made of. The hotter the oil get the more the friction the more the clutches will hold.
About the whinning problem the control value assembly is leaking possibley the cast iron housing is worn or scard and causeing the fluid to leak thous the noise at low speed. no real probme just lose a little presser. Try replacing the control valve assembly . the only differentice between the earthmovers and boat is that they use air operated control valve verse a manual operated cable.
Pull the motor to replace the rear seal in the tranny.
Do you have tranny coolers ??. If not put a set on to keep temp. under 300 degers or you will cook clutches.
PS. B/W 71C will easely handl 1500hp if you keep in the water
