-   -   soft transom! (https://www.offshoreonly.com/forums/general-q/75497-soft-transom.html)
Formula29 03-30-2004 06:52 PM
soft transom!
I was bolting on new bravo Transom's to my 29 formula p.c and it appears that the lower transom is a little soft, as I tightened the lower bolts the inner transom plate cracked! The rest of the bolt's torqued fine. And the seal is tight to the hull. Will this be o.k!
mcollinstn 03-30-2004 07:29 PM
No, not really okay.
Formula29 03-30-2004 07:35 PM
what do you do? replace transom?
mcollinstn 03-30-2004 08:33 PM
Yessir. At least the rotten portion of it.
Find somebody with a moisture meter to check the transom to determine the full extent of the soft/wet wood.
Then you can make a decision.
dockrocker 03-30-2004 08:54 PM
That could be a big job. Not sure how the transom/stringer arrangements are in your boat, but it's possible that water has migrated from the transom to the stringers (or vice versa). Definitely need to get it checked out, once it's in there, it's only going to get worse!
