-   -   Polyester gel over marine tex (https://www.offshoreonly.com/forums/general-q/75768-polyester-gel-over-marine-tex.html)
blue thunder 04-02-2004 05:43 PM
I have a number of scrapes or screw holes that have been repaired/filled with marine epoxy, marine tex. Although the marine tex is white, it looks crappy. I would like to finish these areas off with either gel coat or something that will give a similar like new result. However, I remember reading somewhere that one should not go over epoxy with polyester gel/resin. Is that true? If so, what might I use to repair these epoxy filled areas to like new condition? Some of these areas are under the water line, like on the keel from trailer debacles. Any ideas?
BT :cool:
Kidnova 04-03-2004 02:10 PM
Dave,
Maybe the "naked girl" thing would work here ;)
blue thunder 04-03-2004 05:28 PM
How'd you like that little trick Bill? I ended up with good advise on a boring subject :doggy:
BT :cool:
Kidnova 04-04-2004 12:20 PM
Must be no one repairs their glass or gel....just let it go to chitt.
Tampons looks like the fix. Happy tuna fishing :fish: :crazy:
mcollinstn 04-04-2004 05:22 PM
I've never used gel over epoxy. I'd expect that it would work fine as long as the epoxy was fully cured and wiped with a solvent that was friendly with gel.
If there is still any sort of chemical activity going on with the epoxy, I would not attempt it.
