-   -   Aluminum heads in saltt water?? (https://www.offshoreonly.com/forums/general-q/7619-aluminum-heads-saltt-water.html)
cdaniel525 02-07-2002 09:44 PM
I was wondering if aluminum heads will corrode in salt water over the years?? I have seen a lot of talk about them being better and was considering using aluminum when i rebuild the top half of my SBC this spring. Is this the same case with aluminum intakes??
Audiofn 02-08-2002 12:34 AM
You can if you are rebuilding go with a closed system and then you will really have a long lasting set up :D :D
Jon
cuda 02-10-2002 12:52 PM
I just put closed cooling on my new engine because of aluminum intake. I think it will be worth the investment. ($570). It will also legnthen the life of the exhaust manifolds. Another advantage of the closed system is the ability to run at a higher temp, so the engine is more efficient. It isn't a very hard job to install the closed system either.
Very sweet boat by the way. I love a restored classic boat. I am restoring an 81 Formula.
[ 02-10-2002: Message edited by: cuda ]
cdaniel525 02-12-2002 11:39 PM
Thanks guys...
Im gonna look into a closed system... cuda...yours was $570 for both motors or just the one??
Good luck with the formula
BTW, ur name "cuda" referring to a plymouth barracuda??
cuda 02-12-2002 11:41 PM
It was $570 for a full system (includes exhaust manifolds) for one small block chevy. The nickname is short for Barracuda, it is a name that has been with me for years.
blue thunder 02-14-2002 06:51 PM
ttt
