-   -   alpha lowers (https://www.offshoreonly.com/forums/general-q/76367-alpha-lowers.html)
glassdave 04-10-2004 09:11 PM
alpha lowers
OK heres the deal. i have an 85 chris scorpion with the original gen1 alphas on it. i hava a line on a lower that i am pretty sure is a late 90's or so alpha. will that late of a lower fit on my early drive. thanks guys :cool:
marinetrans 04-10-2004 09:31 PM
Only if its a Gen 1 lower. Can't put a Gen 2 lower on.
glassdave 04-10-2004 09:36 PM
thanks MT . . thats what i needed to know. i dont have the benifit of being able to compare the two side by side before i buy. my boat has the original gen1's and the drive in question came off a late 90's donzi classic i believe. thanks.
marinetrans 04-10-2004 09:42 PM
Put a counter-rotation lower on the port side, if the boat rolls to the left it may stop it. Boat will handle better too, docking and under way.
glassdave 04-10-2004 09:48 PM
i was thinking of doing that but was having trouble locating a gen1 lefty. boat seems to handle pretty well now but it would be nice have a counter rotator on it.
Big Block Billy 04-11-2004 11:49 AM
Have a good drive shop make one up. It may cost a bit though! BBB
glassdave 04-11-2004 12:13 PM
BTW does anybody know the year they stoped making the gen1 alpha
pullmytrigger 04-11-2004 12:44 PM
so you can change just the lower and make the drive counter rotate???
glassdave 04-11-2004 12:49 PM
thats correct twin. the counter rotation is in the lower. i think there is a few more minor things like cable orientation. but the lower itself handels left or right rotation :cool:
Big Block Billy 04-11-2004 12:51 PM
91 was end of gen1 in new boats.
glassdave 04-11-2004 12:52 PM
thanks BBB :cool:
glassdave 04-11-2004 05:58 PM
by the way, anybody have an idea what my case ratio is. its the stock merc 260 hp small block chev 1985 gen1 alpha. thanks
Caincando1 04-11-2004 06:40 PM
I looked at an 85ish 26 CC scorpion with a gen two drive on the counter rotating side. I'm not sure what they did but it can obviously be done.
Brian
Formula29 04-11-2004 06:59 PM
my old formula 1985, had twin 260"s with the alpha's and they were 1.5 ratio, They have also came out with aftermarket alpha 1's, you can get a bran new lower for around 600.00, I bought a complete outdrive for I think 1100.00 stearndrive enginearing
glassdave 04-11-2004 09:54 PM
F29- i just saw an aftermarket one on ebay priced about the same as you mentioned. you were pretty happy with it than i take it? i think it was an aftermaket case with merc internals. thanks for the info
