-   -   Interesting OEM 522 Whippled EFI engine build. (https://www.offshoreonly.com/forums/general-q/76717-interesting-oem-522-whippled-efi-engine-build.html)
Infomaniac 08-17-2004 09:50 PM
Re: Interesting OEM 522 Whippled EFI engine build.
Putting the balancer back together. Engine is balanced with only the counterweighted center section.
http://www.riverratlife.com/uploads/info/balancer.jpg
Infomaniac 08-17-2004 09:51 PM
Left one cylinder head off until I had the timing cover and balancer. Need to use the piston stop tool to find exact TDC.
Found it. You might notice the engine changed color also.
http://www.riverratlife.com/uploads/info/found.jpg
The GM Gen VI timing cover has a pointer built on. The stock balancer is 8" and the new one is 7" . Will not work. Was worth a try.
http://www.riverratlife.com/uploads/info/tried.jpg
A quick cutting wheel job on the stock timing pointer and a new billet adjustable pointer will do the job.
http://www.riverratlife.com/uploads/info/pointer.jpg
Infomaniac 08-17-2004 09:52 PM
Installed the other cylinder head, remainaing valve train and timing cover for good.
One last look around in here.
http://www.riverratlife.com/uploads/info/last.jpg
Should not be a problem filling these cylinders. What looks like a step is a digital camera optical illusion. The black is the hard anodizing. The entire head casting was hard anodized before machining.
http://www.riverratlife.com/uploads/info/fillit.jpg
Infomaniac 08-17-2004 09:53 PM
Thanks GM for providing this intake valley pan. It is a nice feature. Will keep the hot oil from splashing the bottom of the intake manifold. The intake will have an integrated intercooler as well. Every little bit helps.
http://www.riverratlife.com/uploads/info/valley.jpg
Better update some posting on this project.
Will be fairly direct and to the point.
Dooley supplied pan pick up.
http://www.hotboat.com/image_center/...pickup-med.jpg
Infomaniac 08-17-2004 09:54 PM
Windage tray complete and installed.
http://www.hotboat.com/image_center/...indage-med.jpg
Oil pan on.
http://www.hotboat.com/image_center/...oilpan-med.jpg
