-   -   Oil Filter for Mercruiser Remote Kit SBC (https://www.offshoreonly.com/forums/general-q/76758-oil-filter-mercruiser-remote-kit-sbc.html)
BAD-HABIT 04-15-2004 12:18 PM
I plan on installing my the upper half of my motor this weekend and from the looks of it the Mercruiser remote oil filter kit I purchased also. Question is this....It seems like the oil filter will need to be kinda short. At least shorter than normal...I think:rolleyes: Is this true? the kit is the type that mounts the filter in the same vertical fashion as on the block. I am assuming that this means I do not need an anti-drain back feature on the filter correct?. I plan on using Napa/Wix filters as usual. Thanks in advance folks....
Randy
Bad-Habit
