-   -   580ci HELP (https://www.offshoreonly.com/forums/general-q/7696-580ci-help.html)
cigarette39 02-11-2002 10:06 PM
580ci HELP
HI, I WOULD LIKE TO KNOW IF ANYONE CAN HELP ME ESTIMATE THE HP AND TQ MY ENGINE WILL MAKE WITH THIS COMBI THAT I HAVE. 580CI CHEVY, MERLIN 345CC IRON HEADS PORTED, 9.5:1 COMP, MERLIN SINGLE PLANE REWORKED BY WILSON MANIFOLDS, 1050 DOMINATOR HOLLEY, CRANE CAMS #138101 MECH. ROLLER 254/262 DUR. 112 LOBE .714/.714 LIFT. ANY INPUT WILL HELP. THERE IS NO DYNO AVAILABLE IN THE VIRGIN ISLANDS THATS WHY I NEED INPUT. THANKS. :confused:
skunknet 02-11-2002 10:27 PM
You have a better breathing version of my 572". You have bigger 345cc heads versus I hogged out a set of 320cc Merlins. You have 9.5:1 compression versus my 8:1 which gives you a 6% additional hp. You have a bigger cam. We have the same carb and I ran a single plane Brodix intake. Guessing 760hp.
Chuck
[ 02-11-2002: Message edited by: One Big Screw ]
WETTE VETTE 02-12-2002 08:27 AM
Desktop dyno shows 694 HP @ 5500 RPM
726 FT-LBS. @ 4500 RPM
That is using large tube headers with open exhaust and putting the cam in on a 112+4.
cigarette39 02-12-2002 12:20 PM
WETTE VETTE HOW ACURATE IS THE DESK TOP DYNO. HAVE YOU COMPARED IT WITH REAL DYNO RESULTS AS YET? THANKS.
WETTE VETTE 02-12-2002 02:05 PM
With stock parts it comes very close. One area of uncertainty is in the heads. I choose "fully ported rect. port with 2.30" int. and 1.90" exh". This is just a guess that is probably close to what you have. If you have the flow numbers I can enter them in and probably get a little closer. The next option for heads if you don't know your flow is pro stock heads, which are like a fully ported big chief. I doubt your heads flow this good. On an LS6 Chev. the numbers come out right at 460 hp which is what the advertised power is.
cigarette39 02-12-2002 06:33 PM
THANKS WETTE VETTE FOR THE INPUT. ANYONE ELSE HAVE ANY INPUT THAT CAN HELP ME KNOW WHAT I CAN EXPECT. WETTE VETTE MY HEADS WAS DONE BY JIM VALAKO AND I AM GOING TO GET THE FLOW # FROM HIM SO I CAN GIVE YOU. THANKS.
cobra marty 02-15-2002 08:34 AM
1.2HP/CID will be very close for your setup. That is 696HP.
