-   -   Diagnosing noise in valve train. (https://www.offshoreonly.com/forums/general-q/77081-diagnosing-noise-valve-train.html)
Danny_Ocean 04-19-2004 08:19 PM
I have a "ticking" sound coming from the starboard head. How do I determine the difference between an exhaust leak, a sticking lifter and/or a bad valve spring?
Thanks in advance,
D. Ocean
Pompano Beach, FLA
paradigm shift 04-19-2004 10:27 PM
Re: Diagnosing noise in valve train.
Well I am old school so I usually use a piece of hose as a stethascope to listen to valves etc. They do make nice ones with a long tube like a doctor carries but I seem to never have one around when I need it. Long screw driver also works. Kind of shade tree but you will be able to here which valve noise is coming from if it is a valve.
Look around your exhaust usually there are some visual signs of leaks. Hard to see if you do not have much room. Flappers - I have Teague switables and they drove me crazy for a while. Thought it was a lifter - valve noise.
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Danny_Ocean 04-19-2004 10:35 PM
The flapper noise is distinct...sounds like 100 monkey's hammering on a garbage can. Drove me nuts trying to figure out what/where that sound was coming from!
I don't believe it is an exhaust leak as I just replaced the manifolds (incl. new gaskets). Re-torqued twice.
I'll try the rubber hose trick.
Many thanks,
D. Ocean
Pompano Beach, FLA
gmhdfan 04-20-2004 06:38 AM
If it is an exhaust leak spray (spray bottle) some tranny fluid down the carb while running and look for some smoke coming out of somewhere. Works great every time.:)
paradigm shift 04-20-2004 11:21 PM
Gota remember that one. :D Hope I never need it.
