1998 baja 24 outlaw se windscreen...
anyone know where i can find one like what comes on the new 25's? i want something that will fit on the ridge of the fiberglass, and would like to stay away from the kind that look like little windows in front of your face, ya know?
little windows
If you change your mind and want to go with the little "windows" ( which happen to work) then let me know - I can put you in touch with a mfg. in St L MO.
MAV |
little windows it is!
mav, i would appreciate your help locating your suppiler. |
These people can make any demension you want with a hard bend. e.g. not an arching bend along top of wind screen ( However, the salesman I dealt with knew of a competitor who could do this.)
I have two small ones screwed into back of my windscreen - then about a 37 deg flat bend up. I tried some flat alumanum samples before deciding how tall and wide I wanted mine to be and had them radius all the corners to 1.25" Mine are clear -- though they can make them with a smoked appearance. I prefer the clear ones - "unless you are in the boat or looking for them - you NEVER even see them ( boat lines remain clean). I can try to take a digital pic if you'd like. Mine are polycarbonate - but they offer lexan - e.g. hockey rink glass - nearly unbreakable! ACI Plastics 3945 W Pine POBox 8070A St Louis MO 63156 Plastic windscreen acrylic, also lexan/polycarbonate |
ttt
| All times are GMT -5. The time now is 02:55 PM. |
