?? Stereo speaker switch OFF/ON
1 Attachment(s)
Q?: I'd like to be able to have the option of switching off the 2 cabin speakers but keeping everything else thumping. Can I do this without damaging the head unit (cabin speakers are being run directly off the head unit / not thru amps) and two... is it as easy as putting a toggle switch in line? Any other suggestions? :confused:
Blue by You,
I would first start by getting a few more amps! I am not sure if 1600 watts is enough A simple switch from Radio Shack should work.. Nice system. fightclub |
That's pal... but you're not counting the additional 600 watts under the rear bench :cool: :cool:
So you see no problem in doing so? I've seen speaker switches (small dials) that control the volume as well as having an OFF position. Is this what I need? |
Potentiometers will wear out pretty quickly and cause static in your speakers. Best to just use a hard contact switch. I had the same problem, but fortunately you can turn your internal power off with Alpine head units.:cool:
Are you cabin speakers wired to your head unit off the front or rear speaker connections?
Are your amplifers connected to both front and rear RCA outs? If your running the cabin speakers off the front and amplifers off the rear, you could fade out the cabin speakers. Otherwise a switch would work fine..... |
Originally posted by Rivercrazy Are you cabin speakers wired to your head unit off the front or rear speaker connections? Are your amplifers connected to both front and rear RCA outs? If your running the cabin speakers off the front and amplifers off the rear, you could fade out the cabin speakers. Otherwise a switch would work fine..... |
switching off + or - will kill the circuit. The amp won't see the load with one leg off.
Audiophiles would tell you that the switch will ruin the quality of your signal path... but let's face it, your not in an audiophile situation. |
So it looks like I can switch these no problem! Very good! Thanks for the info. I'm going to try switching it this weekend. I'll let everyone know the outcome.
Jim
I did the same thing with mine. Because I have the TV & DVD surround sound hooked up so I can turn the cockpit speakers off. I just used a typical automotive on off switch. I actually have two one where I can turn the cockpit off and one that turns the cabin off. Just wire them into the remote lead from the stereo. Works great. |
Jeff;
I didn't even think to ask you. :crazy: :crazy: I'd imagine I would have seen your set up last Saturday if you could have stuck around. Anyways, that is this weeks project. The wife and kids need a place a bit quieter so I thought this switch might help when the wee ones are napping. |
| All times are GMT -5. The time now is 11:18 AM. |
