-   -   gen 6 flywheel /reversible gear (https://www.offshoreonly.com/forums/general-q/77367-gen-6-flywheel-reversible-gear.html)
excaleagle42 04-23-2004 07:26 AM
is there a gen 6 flywheel where the starter gear can be moved to the other side to accept a top mount starter like Mark 4's have on a TRS setup? The new ones I got from the Chevy dealer have to go back because they aren't reversible and the machine work would be more than a new one. The mark 4 stuff will work, they will just be hard to balance.
Thanks for any help
Crazyhorse 04-23-2004 11:19 AM
Yup. Mine are GenV and are cut for a ring gear on either side.
excaleagle42 04-23-2004 11:42 AM
are they chevy ? any idea on a part #?
thanks crazyhorse
merlin540 04-23-2004 12:33 PM
ANY MACHINE SHOP CAN CHANGE THE GEAR FOR YOU AND MACHINE IT TO GO ON EITHER SIDE:D
excaleagle42 04-24-2004 08:49 AM
i gave the machine shop the decision to cut the new flywheel for the gear change to the other side or use the Mark IV flywheel. They decided since I'm using a stroker crank and they had already spun it on the balancer, it would be easier for them to just use the Mark IV and add some mallory metal to the crank which is fine with me. I'll take the Gen 6 flwheels back to the Chevy dealer.
