-   -   will not start (https://www.offshoreonly.com/forums/general-q/77481-will-not-start.html)
Bobnoxious 04-24-2004 10:33 PM
will not start
Everything was working perfect. The engine started everytime you hit the key. then it lost all the fire no spark turns over just will not start. power to coil but I must admit electrics are not my thing any help would sure help Im lost with this one.
obnoxus 04-24-2004 11:16 PM
ya didnt pull the lanyard out did ya?
Mr. Demeanor 04-24-2004 11:47 PM
This thread is..well...pretty obnoxious so far :p
If the lanyards in, check for spark then fuel pump.
Griff 04-25-2004 04:09 AM
Pull a spark plug, reconnect the plug wire, and then crank it over. See if you have spark getting to the plug.
Water Pistol 04-25-2004 07:16 AM
I had a no start problem on my 1st attempt this spring and it ALWAYS fires in short order. Manifold was wet with gas so I pulled a plug, held it aginst a manifold bolt only to find no spark. Damn!
When double checking everthing, I noticed that I had only connected up one battery. After connecrting the other battery, I had spark. Turns out my MSD sparkbox must pickup its power from my #1 battery (cranking) only. (Gee, think that red wire ring terminal does anything?)
Is usually the little things we overlook that frustrate us the most.
FWK 04-25-2004 06:07 PM
DOH!!!!!!!!!!!!!!!
Bobnoxious 04-26-2004 07:28 AM
Thanks for all the help everything is connected checked plugs for spark checked coil for spark checked everything
Doh!!!!!
RJ1340 04-26-2004 08:45 AM
EFI or carb? I'm dealing with some EFI computer problems right now.
obnoxus 04-26-2004 09:17 AM
Ok,, assuming you had spark ( you never said yes or no ) ,,, you eliminated alot of systems and narrowed it down to fuel,,,,,,,,. assuming nothing catastrophic happened.
Well assume you have efi because carb would be very obvious if you were getting fuel or not.
find a pressure guage and see what you have.
Bobnoxious 04-26-2004 11:29 AM
it is a carb nothing fancy got fuel no spark. I guess it is time to buy a coil or module. I
blue thunder 04-26-2004 07:07 PM
Try running a jumper wire from the positive side of the battery to the + terminal on the coil and crank it again chicking for spark.
BT :cool:
Bobnoxious 04-26-2004 07:51 PM
The trigger was bad changed it and wham running again
