-   -   Small Block Chevy Cam Selection ?? (https://www.offshoreonly.com/forums/general-q/77518-small-block-chevy-cam-selection.html)
SMOKE THIS 04-25-2004 01:28 PM
Help on selecting Cam for optimum Performance no more than 5500 RPMS.
Current Setup: (19ft stern drive, fresh water)
350 bored over .040 (flat top pistons)
Edelbrock RPM Aluminum heads (64cc), max lift .550
Harland Shape Rockers 1.5 ratio
Edelbrock RPM Intake
Holley 750 Double Dumper
MSD Ignition
4 inch exhaust
Not sure what compression would be now with this new setup (guesing start was at 8 :1)
Investigating Comp Cams - Help
jaroot 04-25-2004 01:41 PM
flat tappet or roller?
traviss 04-25-2004 01:54 PM
with flat tops
.025" deck clearance ( stock blocks),
.015" shim gasket,needed to keep quench around .040"
64cc heads.
Will be a little less if I had the valve pocket cc's
CR is around 11:1. if all my numbers are correct
will require more then 93 octane.
SMOKE THIS 04-25-2004 04:35 PM
Wanted to use normal gas (not over 93 octane)
What can I do?
Flat tappet was my thought, Comp Cams I was looking at (but have to idle)
12-240-4
226/236 intake/exhaust
480/489 valve lift
112 LSA
or
12-236-3
218/224 intake/exhaust
462/477 valve lift
112 LSA
or
XE 258 H
224/230 intake/exhaust
477/488 valve lift
110 LSA
traviss 04-25-2004 04:50 PM
which pistons did you put in it? stock or aftermarket? trying to find a part# to look and see how many cc's the valve pockets are.
I would think you would have to switch to a dished piston.
SMOKE THIS 04-25-2004 06:24 PM
Not sure what type (already installed). The have 4 smile type grooves (2 on each side), and have the .040 punched on the top. Motor is a 1972 block (if that helps). I belive pistons are nothing special?
Again thanks for the reply. I am leaning towards the Comp Cam 12-240, but a little worried about reversion, idle, and being able to plain off. Is that Cam too much?
I thought max range was 1600 to 5800 (will never get to 5800), that what the JEGS magazine indicated.
traviss 04-25-2004 07:00 PM
those are normal replacment pistons. universal, thats way they have 4 reliefs on each piston. With those 4 valve releifs your CR might be a little lower, maybe around 10.5-10.6 :1 maybe, just a estimate.
You should have no problems with that cam. I ran a 234/242 duration on a 112 lsa roller and had no reversion. I had it set to idle around 800.
SMOKE THIS 04-25-2004 07:19 PM
See your other 'thead' going (to cool.... similiar boats). So stay with the Comp Cam 12-240-4 ?? With all other setup stuff as stated in my original thead message, you think I should be all right ie: 750 double pumper, RPM Heads, RPM intake. What cam are you rocken at ?. Pretty darn fast in a 18.5 footer (what waterway). Any other motor suggestions?
traviss 04-25-2004 07:29 PM
that cam sounds good. If you haven't ordered the heads yet, see if you can get them with a larger combustion chamber to drop your CR to under 10:1. I had great luck running the edelbrock air gap intake on my first 383. A 750 will work great on it.
Can you measure and see what your deck clearance is, aka how far your piston is in the cylinder at TDC. Stock blocks are .025" but piston pin heights can change that. That will determine waht thickness head gasket you need.
I just put a crane solid roller in my motor, 250/258 dur. .598/.598 lift
We have a house up on van ettan lake in oscoda. spend most of my time there, and a few runs in the saginaw river/bay
traviss 04-25-2004 07:35 PM
I got a # of 6.1cc for 4 valve releifs. So that brings your CR down to 10.3:1 if my calculator was right :D
I see those heads come in 70cc versions too. That would put your CR at 9.6:1 which is perfect for 93 octane.
SMOKE THIS 04-25-2004 07:40 PM
Already have heads, intake, and carb - gotta good deal and hope I can make it work. Ever down near Detroit, I need help putting motor together - I cant do it (have Red Wing, Piston playoff tickets - ha,ha). Looking at one of your older pictures, you have black exhaust manifolds, where those Crusader 4 inch center risers. I am looking at GLM aluminums (on a money crunch) looking for the best bang for the buck. Any guesstimate on horsepressure with my setup. Asking now, cause what props should I be looking at as well.
Thanks alot for the responses !
I really hope this all works (wifes getting pissed at the money spending)
traviss 04-25-2004 08:24 PM
I haven't been to deeetroit in a long time :D :D I really don't have any time to my own stuff working 60 hrs a week LOL! If i get some extra time I will let you know.
That exhaust were EMI's with aluminum risers
Now I have the EMI manifolds with the stainless tube risers.
A good estimate would be around 370-380 hp I am thinkin..
Run your stock stainless prop with this new motor and decide how many rpms you need to go down, then order a new prop with more pitch. :)
SMOKE THIS 04-25-2004 08:45 PM
What type park plugs should I run? Should I use the rubber type valve cover gaskets or does it really matter.
Any difference going from the Center rise cast iron manifold vs a cost efficient aluminum manifold (glm for instance). Any other useful hints
Thanks again, I'll stop its just cool (yah... and exciting)knowing someone that had done similiar and can trust.
traviss 04-25-2004 08:55 PM
Contact edelbrock and tell them what heads you have, they will tell you what plug to run.
The valve cover is probably premiter 4 bolt, just use the double layer cork with the metal in between. if its center bolt ( on top of the cover in a straight line , used from 1988 and up in gm motors) use the rubber one from gm.
On that particular motor, the center rise stock exhaust would probably be fine. When you start making alot of horsepower then the exhaust comes in handy. The only gain going to aluminum is the wieght savings.
