how much play on gimbal ring?Bravo 1
I'm pretty sure I'm screwed here. My drives are both very worn on the starboard side where it slides against the gimbal housing.The hump is basically gone and when I lift or turn the drives I can see about 1/8" slop at the top AND side bearings. Are the bearings replaceable or is it most likely the gimbal ring gone bad?'90 Bravo 1. What's a good source for the part?
call me at 315 623 7642,i can help you figure out what it needs and give you a good price on the parts,chris
1 Attachment(s)
Hey long as you are pulling the drives back off. ie your other thread fix the gimble ring and bearing to so you dont go though this agian. Other wise it will look like this before summer is over if not worse.
Rag's |
| All times are GMT -5. The time now is 04:25 PM. |
