-   -   cross overs (https://www.offshoreonly.com/forums/general-q/78209-cross-overs.html)
737jetmech 05-03-2004 06:07 PM
cross overs
Has anyone had any luck running cross overs on there engines? I installed them on my engines to clean up the installation.
During running the cams in yesterday ... the temp was cycling as the t-stat opened and closed.I figure not enough restriction in the cooling systems now.Water pressure was also cycling 20 psi to 3 psi @ 2200 rpm static.
Do I need to restrict the exit ports on the t-stat housing?
I'll try a few things and installing the original merc stuff is always a option. Just like the looks of the cross overs but do not want them causing any engine damage.
thanks
Bob
RLW 05-03-2004 07:52 PM
What are your water pressures? 20 psi to 3 psi? Am I reading that correctly? Do you mean 20 psi-30psi?
Do you have bypasses on your crossovers?
Have you done a "search" on crossovers on this site?
There is a ton of information in regards to this topic, in the archives.
737jetmech 05-03-2004 08:10 PM
RWL,
20 psi t-stat closed . 3 psi after t-stat opens. This is running on the trailer for cam break in. I know pressures will change while running on the water.
Thanks... I will search the form on this topic.
Bob
Fuhgedaboudit 05-03-2004 08:13 PM
dont do it!!!!I did the research on the same subject...all the input was too much water pressure, steam pockets, blown head and intake gaskets, etc...if your not running a blower motor, crossovers are gonna drive you nuts and not going to get dependable results with em....
RLW 05-03-2004 09:28 PM
Bob,
There are many people having good results with both systems, crossovers and stock.
Don't confuse information with knowledge. ie Post #4
Russ
44MTI 05-03-2004 09:59 PM
737 Jetmech,
I built some 600ci n/a motors a couple of yrs ago and put the crossovers on them for the same reason, looks.
We also had a little troubleat first, however after we put on the thermostat housings with bypasses and the x-overs everthing worked great. Water pressure, temp, and no condensation in oil. It was a little more plumbing than I expected initially but you need to use all the parts to prevent condensation in oil. Good luck.
Fuhgedaboudit 05-04-2004 06:36 PM
what he said....
Dave F 05-04-2004 07:00 PM
Your problem is due to the Tstat opening and closing as you've said.
You simply need a "minimum flow". drill a hole on both sides of the Tstat plate. about 1/8" on either side.
DAVE
737jetmech 05-04-2004 07:18 PM
Thanks guys ! I'll play with them on Friday and see if any positive results are reached.
