-   -   Guest Onboard Battery Charger? (https://www.offshoreonly.com/forums/general-q/78349-guest-onboard-battery-charger.html)
JimmyBaja 05-04-2004 11:53 PM
I have a Guest onboard battery charger. Printed on it is 30amp, 50amp and 13.6v. Will this charger boil batteries if left on all the time? 1987 boat.
Thanks, Jim
Danny_Ocean 05-05-2004 01:09 AM
I think it might. I'm guessing an isolator/regulator, properly installed in-line will allow you to keep the charger running continously without worry. Some of the better/newer chargers have the technology built-in.
D. Ocean
Pompano Beach, FLA
ofshore 05-05-2004 09:02 AM
Jim, Check these out my boat didn't come with a power supply so i researched them quite a bit, this is the best one i found. If you get one just order it with the IQ4 controller. I've only been using mine for one season but it has worked flawlessly so far.
http://www.iotaengineering.com/dls.htm
http://www.iotaengineering.com/options.htm
bglz42 05-05-2004 09:50 AM
I've been using two Guest 2611's for three years on my cruiser, and just installed one in my Thoroughbred. They've functioned flawlessly, and are left on 24 hours a day. They WILL NOT boil batteries. The charge flattens out to a small trickle. I check the electrolyte in my cruiser's four batteries once a month, and they are very healthy. I hardly ever have to add water, (maybe a little every six months.)
Guest also has excellent customer service. I bought an old boat that had an ancient Guest charger in it that was inoperable. I sent it to Guest and they sent me a new 2611 free of charge!
JimmyBaja 05-05-2004 09:02 PM
Thanks, I was hoping someone would tell me that the Guest converts to a trickle charger.
JimmyBaja
JimmyBaja 05-06-2004 09:59 PM
Does Guest have a website?
JimmyBaja
ofshore 05-07-2004 05:41 AM
jimmybaja, If all your looking for is a charger than the guest chargers work great and like bglz42 said you should be able to leave them on all the time without causing damage to the batteries. The only reason why i did not go with them is because i wanted to use mine for a power supply when i went on weekend trips and guest chargers are not rated for continuous supply. here's their web site. http://www.guestindustrial.com/
russ 05-07-2004 09:08 AM
You might look at these also
http://www.batterytender.com/
http://www.dualpro.com/
JimmyBaja 05-08-2004 11:06 PM
Mine is a 2530a Guest unit.
JimmyBaja
bglz42 05-10-2004 04:26 PM
http://www.marinco2.com/showProduct.asp?p=2530C-B
