-   -   more alignment woes,getting nowhere (https://www.offshoreonly.com/forums/general-q/78386-more-alignment-woes-getting-nowhere.html)
Falcon 06-22-2004 10:32 PM
Re: more alignment woes,getting nowhere
There is another way to see how "close" you are. Get a "digital anglefinder" and check the angle between the transom of the boat and the front of the crank/damper. The engine should be very close to 13 degrees from the transom angle for correct alignment. The back of the engine should be bolted down and only raise and lower the front of the engine, preferrably from a center point. Also be sure to check for correct "bearing alignment" to get the alignment bar to hit the center of the coupler.
Falcon 06-22-2004 10:33 PM
1 Attachment(s)
I messed up a picture of the angle finder I use. Here it is.
Krumbsnatcher 06-23-2004 10:06 AM
Spend the $90 at www.mercstuff.com you will use the tool every year. Once i did i got the damn thing aligned.
cuda 06-23-2004 10:42 AM
When I had my engine installed, the mechanic said he was having a b!tch of a time getting it to go in. He's been doing it for probably 30 years and has all the tools for it. Finally, he pulled the engine back out and found a burr in the coupler splines. Filed it off and it slid right in.
JON242 06-23-2004 01:32 PM
Merkruzer,
I'm in South Jersey and have an alignment tool. You can borrow it if you want. I live in Sicklerville. cell phone 609-320-3046.
Jon
