-   -   Gas Going Up! Prices Going Down. (https://www.offshoreonly.com/forums/general-q/78600-gas-going-up-prices-going-down.html)
HOUSTONPROP 05-08-2004 09:16 AM
GET THE EXTRA PERFORMANCE YOU WANT!
Lab finish your prop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
satin finish> 3 blade>150.00 new or damaged
satin finished 4 blade>199.00 new or damaged
polishing add 25.00 per blade.
ACCLERATOR design add 50.00
Bravo-Rator 4bld design add 75.00
CALL, place order/
send prop in when you need to.
get 25.00 off price.
Eternal Warrior 05-08-2004 09:36 PM
Darin, If all goes well I'll have bravo to send your way. I'm supposed to be able to up my boat next weekend so I can do some testing. What is the turn around time like right now?
HOUSTONPROP 05-08-2004 11:45 PM
turn around time/
all props received will be 5 working days in the shop ,you can always speed up shipping if you want.
in all honesty we have props there that have been there a month.
we have been buried in props,its unbelievable.
but this is driving me crazy,we are going to start working much later in the evening,we will be caught up:rolleyes:
where we will be able to do the props and ship back in 3 to 4 days like last summer.WE cannot and will not have props hanging around much longer.NO MATTER WHAT IT TAKES.
Thanks very much ,Darin
Eternal Warrior 05-09-2004 09:33 AM
Sounds good to me. I'll give you a call after my testing and we can talk about the specifics. With all the good things I hear about your work I'm looking forward to see what you can do. I'm in desparate need of good service experience!! Thanks!
Blewbyyou 05-09-2004 09:46 PM
Darin,
Will these prices be good for the prop I shipped to you friday? What do you think the turn around time will be for my prop? (3 blade mirage with polished finshed converted to ACCLERATOR design ) $275.00???
Paul
26sonic 05-09-2004 11:05 PM
darin what is the bravo rator prop and the cost to make my stock 24p bravo 1 into one ?
26sonic 05-10-2004 12:33 PM
ttt
HOUSTONPROP 05-10-2004 07:08 PM
external warrior/and
External Warrior ,sounds good to me give me a call when your ready.
Paul/blewbyyou the above prices started on Mothers Day.
SONIC26 >Its best if you send me your number and Iwill be glad to call you,then we can PropTalk and see just what you want and need.
Thanks ,Darin
justinVIP 05-10-2004 11:42 PM
Have you ever done a Ballistic prop? It is a somewhat thin blade to start with, and it has a squared off tip with a lift to it. I have a 2102 VIP with a new 350 MPI. I used to have a 260HP 350 in it and ran 56MPH and 4600. With the same prop and this new motor, I am running 4850rpm to 4900, and running 61mph. I am very happy with this, but always like to run as fast as possible. I have a 21P Ballistic prop now. My outdrive is about a 1.62 Alpha outdrive. I wouldn't mind running closer to 5000rpm, to get max speed, but I can't afford to lose hole shot! Don't quote me on the 1.62, but I am pretty sure. I know it isn't a 1.7 or 1.5... it is more like a 1.62 or something similar to that.
HOUSTONPROP 05-10-2004 11:50 PM
Justin VIP
Yes we repair these props they also have a four bld out.
They are very hard to get the wrinkles :eek: out after they are damaged ,but we do ,it just takes a little longer to work on them,I personally like the prop,They perform good.Call if you need to ,later Justin.
Darin:o
