496 Engine Temp
My '02 275 with 496 HO has been running on plane and idling at 180 degrees. I can't remember how hot it was running last year. Does the 496 have 160 degree thermostat? Is 180 a potential problem? What temps are others 496's running? Also, I've heard that 496's have a brass impeller, is that true?
Any input would be greatly appreciated. |
My Merc. 496 service manual list the thermostat at 160.
I believe the motor goes into safe mode at about 190 degrees. Have you changed the impeller for the raw water pump (neoprene?)? |
Mine runs about 165-170. It only gets to maybe 180 after a hard WOT run, but cools back down quickly.
Time to check impeller. |
Thanks for your input guys. I'm going to attempt to pull the seawater pump and replace the impeller. Do I need to lubricate the new impeller? Anything else I shouold know?
