fuel water seperators?
what is a good quality water seperator to use? they will be used on a 454 gas engines.
can these seperators be used in series with the stock seperators or will the flow be reduced too much. thanks in advance |
anyone?
Why would you want to run a second one???
The stock water sep filters work fine. I've had h2o in my fuel and the filter was full of water. |
Hey Griff,
Why a second filter ? I run a second filter inline because I have EFI's with VST tanks and the standard Merc or anyone water seperator/fuel filter from Merc is rated at 70 Microns. That's not nearly fine enough to really protect the VST screen. I had, as have numerous OSO members, many problems with clogged VST screens. No more. I use a RACOR after my Merc filter and have experienced no problems in over 250 hrs. The standard Merc filter will not eliminate debris capable of sticking a needle in a Holley carb. It's not unreasonable to run two filters. Most probably will not need it. But, some may benefit from two. |
I use the fram HP filter separator and it works great, nice drain plug on the bottom to eliminate the water and they come in both 8 and 11 inches, so depending on your fuel consumption requirements you are covered.
I can see running a second filter to filter out smaller particles than the merc one, just don't see the purpose of running a second water sep filter.
So which fuel filter/water seperator is the best? Which one has the highest ratings? I really don't want to put an inline filter also on the boat if I don't have too. If I can get a 2/for 1 job I rather do that...You mention Fram what are it's ratings?
BH |
FRAM is a powerful marketing company. RACOR is probably the most widely accepted professional filter system for your boat.
I use RACOR with the metal bottom. They are available at most marine supply stores. Boaters World, etc. Good luck. |
| All times are GMT -5. The time now is 02:29 PM. |
