-   -   what is norm rotation on BBC ,LH?? (https://www.offshoreonly.com/forums/general-q/78776-what-norm-rotation-bbc-lh.html)
cooltoys61 05-10-2004 09:04 PM
facing harmonic bal if it turns counterclockwise,,is that left hand?
US1 Fountain 05-10-2004 09:42 PM
LH is standard.
But, it is because it rotates CCW(top of flywheel goes to left) as viewed from the rear. So your balancer should be going CW.
To answer your question, the outlet ports are marked on the rear of the pump housing. The hardwalled hose will connect to the RH outlet port. You are using hardwalled hoses for your supply hoses right? (Not the regular soft walled type hoses that are found after your seawater pump thru the coolers on to the crossover)
cooltoys61 05-11-2004 10:36 AM
yes,hardwall. I saw the markings just wanted to make sure what I had. LH it is then(now that I think about it my timing light was flashing to the left of marker when advanced). Thanks. Maybe I just didn't get the belt tight? I'm going to rebuild the SW pump anyway and hook up right and tighten and hopefully be done with it.
