Bravo 1 milky oil and funny sound...
Took the lower unit of my B1 off awhile back. When we put it back on it had a small leak. I forgot and took the boat out Sunday, when I checked all the fluids before leaving the dock I noticed the drive oil was low. I added fluid and decided to proceed. The boat ran great for about an hour then I heard a humming at speed. I pulled the throttle back on the left drive and the sound went down. At idle the sound was gone. When I parked the boat there was milky oil leaking out of the left drive. Water got in the lower unit I suspect, what do you think the humming sound was? Where should I start to ensure everything is checked?
I would pull the drive and have it checked & re-sealed.
D. Ocean Pompano Beach, FLA |
ya why wait till it blows up and costs 1000s
Just the lower, or the whole drive?
The whole enchilada.
milky oil
If it's noisy the damage is already done pull it teait down and replace all worn bearings you'll most likly find most of it in the upper gear box
I agree. Tear it down now while the gears may still be ok. Bearing are most definatly gone.
| All times are GMT -5. The time now is 12:14 PM. |
