-   -   Flywheel for 502 ? (https://www.offshoreonly.com/forums/general-q/78833-flywheel-502-a.html)
checkmate981 05-11-2004 12:34 PM
Flywheel for 502 ?
Does anyone know what flywheel I need to get .A have A gen 6 502 engine(zz 502).
Thanks Dave
kevinr 05-11-2004 04:28 PM
Just went through this with a balance job. Need to know a few things, like Automatic or standard. Pm me or call me and i will give you the run down . Kevin 850-926-6272
checkmate981 05-11-2004 09:10 PM
Kevinr,
Engine was balanced with standard flexplate .I was thinking that standard flywheel for 502 would work ? Not sure if it is the same diamiter of the 454mpi i have in the boat now.
Dave
checkmate981 05-13-2004 06:45 PM
ttt
Madmax 05-13-2004 08:38 PM
GM part # 14096987. Just had this question 2 weeks ago..... it's about 90 bucks from gmpartsdirect.com
hope this helps.!
btw, it's not the same as a base 454mpi. cast stuff vs forged stuff = different balance.
checkmate981 05-17-2004 09:22 PM
Re: Flywheel for 502 ?
Mad Max,
Thanks,That is the flywheel I ordered and is back ordered.I wasn't sure if it was the same diameter as the 454 for the starter and wasn't sure if the coupler would bolt up .I should see it by late June.
Thanks again
Dave
